rear crank seal
just had the rear crank seal replaced still leaking garage going to do it again but this time there going to replace seal plate as well hope this stops it leaking this time any tip welcome thanks
Seal plate shouldnt need replacing unless damaged..If they removed it to replace seal then they would have disturbed the sealent on the sump hence leaking,it is quite easy to damage crank seal and should be a genuine nissan part fitted only:)
hi lee I was there when he replace it all I remember was him removing the plate to fit the seal but don't remember him using sealent when putting it back so is it a case of removing plate an resealing or does the sump have to come off an be reseal an the seal was genuine thanks
Edited by stephenk
Edited by stephenk
There is a gasket on the rear of the seal plate and a rubber seal that attaches between sump and rear plate ...Ideally because the plate has been removed now the rear gasket,rubber seal should be replaced but also the sump should be removed to make a GOOD seal,you may get away with a very small amount of sealant but i wouldnt trust it for long periods..You can change crank seal without removing plate;)
thanks lee I let I let him know on Monday I must be the unlucky zed owner thanks
Edited by stephenk
Edited by stephenk
