Anther headlight question
Don't worry I did a topic search first. I have a 91 JSPEC. As you already know it uses H3C bulbs. My question, will any other bulb fit without having to attach more wires to an H3? Iam having a hell of a time finding H3C bulbs in Germany and my driverside (passenger side for me) is out. The German Polizei love handing out tickets for this......Mike
I don't think you will find any others that fit.
Most bulbs are European standard so I would think if we haven't found any in the UK then you will have the same problem in Germany.
They are dead easy to wire up, you just need a H3, piece of wire and a crimp spade connector. Get someone to solder the wire to the back of the outer metal casing and it's done.
I found it's best to pass the wire through the casing and tie it on then solder as it can get very hot during use and drop off if not secured.
