So today she finally died... went to go for a nice drive in the sun and it started but died after a couple of seconds, and then wont start. This is something that has been developing for a few months. occasionally not starting, then if I leave it for a couple of minutes it will start. The symptoms are that it will turn over but not fire. or fire first time and start, but then immediately die, by what seems like fuel starvation.
Also, I though I had worked out that if I hear the fuel pump prime it usually meant the car would start. this seemed consistent. If I didn't hear it prime then it wouldn't start, pointing to fuel problems.
This leads me to believe it could be the crank angle sensor, fuel pump or FP Control Module itself. I guess it could also be the ECU, although I am less likely to believe this would just start randomly playing up over a long course of 3 months without any other symptoms.
So my points to investigate would be first of all the connections and relays on the CAS, ECU, and Fuel Pump. if they seem fine I would then need to check voltages between cas > ecu > fuel pump. hopefully that will tell me whats what?
Hi guys,
Anything I have missed?
