Engine sump pan
After an engine sump pan please for a 92 NA auto. After noticing a slight oil leak put it up on a ramp and noticed it has been welded previously.
Would the turbo sump be the same as the non turbo and would I be able find a new gasket.
Edited by Lou9890
Hi mate I've got a good engine sump pan from a 1992 NA Auto, £40 including delivery
Sounds good would you also know how I could get a new gasket.
There is no gasket apart from the two half round at the rear and front crank the rest is liquid gasket. And the TT sump is different to the NA
Thank you for the advice. Baz has said that his is for an na so hopefully should be fine. I purchased a few bits from online Auctions before and have been told the parts are the same on both but not the case.
That's because unfortunately a lot of people out there don't know what they are on about and will tell you anything to make you buy.
