(Road tax fund).... Sorry a few bits up for grabs....
Internal N/S door handle, cable and mechanism - £10 + £3 P&P
Lower Plenum older style - £10 + £10 P&P
Pair of throttle bodies and Linkage - £30 +£8 P&P
Rear wiper motor and harness - £10 + £6 P&P
Full set of series 1 red injectors and rail 370cc NA, all caps and injectors in good used condition - £40 + £10 P&P
Pair of OEM TT manifolds in good condition - £20 + P&P
TT oil tree - £10 + £5 P&P
NA fuel pump - £20 + £5 P&P
EGR, PRVR, AIV valves and vacuum piping - £15 +£4 P&P
CAS bracket - £6 + £3 P&P
Pair clear front indicators with internal orange filter - £10 + £4 P&P
2 x pulleys for ancillary belts - £6 + £3 P&P
BMW style clear side repeaters - sold
Alloy MAF adapter - SOLD
Det sensor - sold
Edited by veilside01702
Dropping prices and adding postage cost
  • Replies 31
  • Views 687
Internal N/S door handle, cable and mechanism - £10 +P&P
Pair of used OEM O2/Lambda sensors - £20 pair +P&P
Lower Plenum older style - £10 +P&P
Pair of throttle bodies and Linkage - £40 +P&P
Rear wiper motor and harness - £10 +P&P
Full set of series 1 red injectors and rail 370cc NA, all caps and injectors in good used condition - £40 +P&P
Pair of OEM TT manifolds in good condition - £20 +P&P
TT oil tree - £10 +P&P
NA fuel pump - £20 +P&P
EGR, PRVR, AIV valves and vacuum piping - £20 +P&P
2 x vacuum solenoid valves - £10 +P&P
DET sensor - £5 +P&P
CAS bracket - £6 +P&P
Pair clear front indicators with internal orange filter - £10 +P&P
2 x pulleys for ancillary belts - £6 +P&P
BMW style clear side repeaters - £10 +P&P
Alloy MAF adapter - £5 +P&P
Just to confirm the injector set is for NA engine not TT?
The injectors are old style red connector..... I looked at my TT ones and they are brown.... Plus they came off my old NA.....
iam intrested in the maf apaptor is it still avaliable please.
Yep, still available.....
Paypal Gift cash if possible....
Cheers Neil, received and will get it wrapped and sent to you.....
The wife Posted the part out to you today Neil........ should be with you in a couple of days.....
Do you still have the clear front indicators with internal orange filter.... im new to this forum and dont know how to use it atm please can u contact me asap please
really need these
thanks u
really need these
thanks u
I still have them if you want them.......??
veilside01702@sky.com
Det sensor still around ?
I still have the DET sensor if you want it??
lovely ill paypal you funds now , don't suppose you have the loom that goes to it as well ??
Sorry, I only have the sensor.......
