I'm looking for a auto turbo exhaust housing. One of mine has cracking round the hole for the wastegate. I don't want to reuse it....
Anybody got one?
I have some auto turbos, but they're in good working order. I'd take £100 for them, they could always be sold on once you've swapped the turbine housing.
I might have a tired single one or two kicking around, but I tend to have them rebuilt to hybrid spec.
What do you define as hybrid spec Noel? Gaz has the same kit as what I fitted. All new bearings, seals etc with 360 degree trust washers and step gap rear seals.
Fully rebuilt with larger diameter compressor wheels & 360° thrust bearing. They produce around 460bhp & 470lb·ft at a peak of 1.35-1.4 bar. This is with uprated SMICs, air filter & full turbo-back exhaust system only. 2" pipework & single intake, standard MAF.
2.5" pipework & dual intake with blow-through MAF should see 500bhp & 500lb·ft at 1.5 bar.
As the new dyno draws nearer, I am beginning to get some serious intake & turbo modifications planned out. The new blow-through MAF requires a huge amount of mapping alterations, the data given with the sensor is pretty useless :(
