In memory of Mandy
Ecu
Anyone have a spare working stock ecu for my Manual UK twin turbo? I currently have a Mines one but want a stock one so I can get a Nistune.
Thanks, Dan
I can supply a fully plug & play Nistune ECU, all ready to go :)
Here's a couple of Nistune ECUs plus a remapped Turbonoz ECU that were done the other week :)
Yes, I still plan to come and see you in the spring for a Nistune but thought you needed a stock ecu in the car already? If not, how much extra is it for you to supply the stock ecu aswell?
If yours is a genuine Mine's, then the reason it can't be used is due to the epoxy-like substance they cover the EPROM with. Any other ECU will suffice.
The cost for a plug & play Nistune ECU is £275, it works out cheaper than buying a stock ECU and then having the system installed, even in dollars :laugh:
