My HICAS light comes on occasionally, and goes out when I top up the level. However I do have a leak somewhere in the system as I have to top it up nearly every month.
Most of the time it is fine, but every now and then I will pull up at traffic lights to find smoke billowing out from under the car!:eek: At first I thought it was a buggered transmission, but I'm sure its from the power steering system as the auto box fluid level never changes, only the P/S.
I have checked all around the P/S resevoir but can find no leaks, but it must be leaking somewhere near the exhaust because of all the smoke.
As I say, this only happens occasionally (usually after I've been thrashing it).
Any idea what the most likely component is that's at fault, or where to start looking?
Neil
