MeisterR GT1 Coilovers - Opinion
MeisterR has*been working over the past 2 years on the development of an amazing British engineered suspension.*
We didn't want to make something simply different, we wanted to make the best and compete with the best offerings on the market.*
We have finally arrived at the finish line and the new MeisterR GT1 Coilovers are finally ready.
The GT1 coilovers are developed*in collaboration between MeisterR and Black Art Design (BAD).*
BAD is a well known British suspension company responsible for many race winning cars.*
Their portfolio range from the DAX Rush, Noble, Classic Austin Martin, to the fastest privateer Ford RS200 in the Colorado Pike Peaks.
The GT1 coilovers have many custom in-house made parts that are truly cutting edge engineering.*
As there are so many technical features on the GT1 coilovers, we are still compiling a presentation that can show off these features in an easy to read format.
But here is a little teaser video I made up for the GT1 Coilovers
http://youtu.be/GXsTFyuo8UM
The GT1 coilovers retail at £1650, and we want to provide a few benefits to members that may be interested.
Here are a few points we are thinking about and we want the community's opinion.
1. *Life-Time Warranty on hydraulic function to the original purchaser: *
That is right, the GT1 damper is built to such a high specification that technically speaking, unless it is physically damaged (such as a bent / scored shaft), it will continue to operate forever… even under racing condition.*
However, parts exposed to the element will wear over time so you really can't give a lifetime warranty on those, but the actual damper itself will continue to function for years, we are that confident of the quality.
The warranty means, if you go to Nurburg every weekend and a damper failed after a run 3 years later, we will rebuild it for free.*
If you crash into the Armco and bent the rod, or run into the gravel and scored the damper shaft causing the damper to fail, then it isn't cover.*Sounds pretty fair?
2. *Upgrade from Zeta-S / Zeta-R / Europa to GT1 Coilovers:
We feel that some MeisterR owners would want to upgrade to the GT1 in the future.*So we want to make an upgrade program for those who have purchased the Zeta-S / Zeta-R / Europa coilovers.*
Our initial thought is, you can purchase a set of GT1 coilovers, and after installation you can send back your old set of MeisterR coilovers and we will refund you £350 (Around 50% of the purchase price) for your old set.*
That way you get a brand new set GT1 in your hand, and there is no need to try to sell the old set of suspensions or wait for a rebuild.
So what do you think of the life-time warranty and the upgrade option with the GT1 Coilovers?
Do you have anything else that you feel could be beneficial to the end user.
We are always open to opinions and suggestions.
Jerrick / Edwin
Edited by MeisterR
As the saying goes, pay the price and you get the quality. I don't have a set of your coilovers myself but I've heard many zed owners praising their quality. Also, it's nice to see you're not just looking after your new customers but also your old customers. Something that sadly is becoming a rarity with new companies out to make a quick buck. Keep up the good work.
A few owners have ask me about more details of the GT1, so I thought I give a little more info.
While the outside of the GT1 look similar to the Zeta-R, the internal is completely different.
I'll try to name a few parts, but there are quite a lot:
1. GT1 Piston: Precision CNC Aluminium: there are quite a few feature in this piston, I will work put up the details later.
2. GT1 bump stop: Progressive rate bump stop design to come into play progressively to aid comfort.
3. GT1 damper shaft seal: CNC made in house using Ultrasound tested Austrian Polyurethane.
A normal damper will never exceed 40 bars of pressure, our shaft seal is rated to 400 bars.
This damper shaft seal is one main reason we offer a Life-time Warranty, because it is actually that good.
Like I said before, the life-time warranty is for the life of the original purchaser, but no limitation on time or miles.
The long as nothing is physically damaged such as a bent rod or a score shaft, we will rebuild it free of charge if oil leak because the shaft seal fail.
BAD have use this seal in Rally Cars that come back for a rebuild 5 years later and the seal look new.
This isn't something that can be bought off the shelf, that is why we make them in house.
We haven't done any back to back testing against the Zeta-R (also it is something difficult to quantify).
But we know the GT1 will out last the Zeta (or any other suspension for that matter) pretty much in a test of durability.
The GT1 use an ultra high heat index hydraulic oil from Millers, what that mean is the GT1 will not suffer fade issue no matter how hard you push the suspensions (BAD use the same oil in Rally cars).
All the internal of the GT1 are made in the UK (most of the bits are CNC machined… in Essex), and assemble at BAD headquarter in Essex also.
All in all, we done everything possible to improve the suspension performance and durability.
A lot of the engineering are bespoke and way above what are normally seen in the suspensions world; we want the GT1 to be a suspension that will set a new bench mark.
Jerrick
  • 4 weeks later...
A quick view of the first few set of the new MeisterR GT1 coilovers.
Mitsubishi Evolution X [ CZ4A ] ( Also available for EVO4 CP9A to EVO9 CT9A )
Toyota GT86[ ZN6 ] / Subaru BRZ [ ZC6 ]
Nissan Skyline R32 GTR [ BNR32 ] ( Also available for R33 / R34 / R35 )
We will have more technical details for release soon. :)
Jerrick
  • 1 month later...
We are just back from displaying at Autosport International with the MeisterR GT1 as it's centre piece.
Here is a few photo of our "little" stand. :)
A lot of interests from many owners regarding the GT1 coilovers.
Many have heard about the GT1 but it was not until they see the internal parts of the GT1 in person that they are thoroughly impressed.
We have a lot of data to present so we will bring out more details regarding the GT1 once we organise them.
Jerrick
They look good, would you provide a better refund for a set that have been fitted to a car but the car has never actually been used? (10 months fitted) Been on stands for the majority of time.
More of a questions of what you done with the car in the 10 months.
If you are interested in the GT1 I'll work something out for you. ;)
But given the condition you probably make better money selling that set privately on the forums, technically it is new.
Jerrick
Carried on building mine haha...still going. Not seen the outside elements yet. However I would love to try the GT1's
With the GT1, we have a lot of choices as these are all custom build.
So let us know once the car is build, and we will make sure we can provide a suspension that will get the most out of your car as well as do everything you need it to do. :)
That is why we have a vehicle dynamic engineering on board.
It is easy to built a suspension that fit, much more to built a suspension that work… and the latter is what we do. ;)
Jerrick
