protoj · Tuesday at 18:48 2 days
Hi All!
I've been having a hissing noise on overrun as the revs drop down. This Only occurs between 2500 and 2000rpm. It will go on for as long as you are off the throttle, and in between those revs.
It even happens when in neutral and the engine is revved above 2500 and your foot taken off the accelerator.
Does anyone else have a similar noise?
