Electronics advice
I have 2 large electro magnets that ime using for a project at home..they are rated at 207vdc. Ive been driving them with 35vdc as thats all i can achieve and allthough still very strong at that voltage they will be monsters with 207 volts running through them,so my question for our Electronic heads is whats the best and most reliable way to convert 240acv to 207dcv?? ime thinking something along the lines of a DC motor speed controler..is this right?
A transformer and some sort of capacitor rectifier circuit.
Brochure here, You just need to look around for something with your input specs and your output specs.
http://www.jameco.com/Jameco/catalogs/c271/P244.pdf
There are variable transformer units, but you will need a rectifier unit to get your DC output.
Edited by Hollings
After more rooting and reading ive just found out i can achieve 200vdc from the speed controler out of a treadmill...should be able to find a knacked one off the Bay...cheers anyway
That's pretty cool, post some pics up of the setup!
What you using the magnets for anyway if you don't mind me asking?
