Me again.
So I have two questions:
RobHowl ·
Hi all,
wondering if someone can point me the right direction or a link to ebay etc
Ive got a HKS Mushroom filter, but that alone,
I have no adapter plate for the MAF or fittings, and obviously looking to fit it
Help would be appreciated
Alex
