Few bits needed
Looking for the following parts
ACL bearings main and rod standard size, obviously new
Nissan oil pump new
Nissan water pump new
NA oil squirters
Let me know if you any of the above
Paul
I've got a complete set of standard size Clevite/Mahle mains & big ends you can have for £100.
If the crank hasn't had to be reground do you just use stock sized bearings? Also can you replace these without fully disassembly of the long block, ie turn the block upside down with the heads still on.
Yep if it hasn't been ground use standard size bearings, you can change the bearing without disassemble of the whole engine
How come you've not used them dude? Is that posted?
Bought them for my insane TOTB deadline but didn't have time to have them fitted.
Yeah, I'll do them for that posted for you :)
Edited by Noz
