IAA and air reg
Any one tell me if this is ok as it don't seam too close up the spring looks ok image.jpg
From my understanding it looks OK.
There is supposed to be a small gap so as to allow a small amount of air from cold so as to aid start.
What happens then after the engine is running is voltage is applied to a heater within the unit which in turn closes the disc with the aid of the spring, thus cutting of the air. I think it should take about 30 seconds or so, by which time the other valve takes total control of idle.
ps is there a base idle screw in the second unit? it looks to be missing. Or have you removed it?
Yea iv took it apart and cleaned them both it was crappy in there I took the screw and the other springs out too help cleaning it's now put back together apart from that as I wasn't too sure if it was ok
