TPS. Question
Hi
I had to remove the TPS yesterday and to set it correctly I used a guide on Google although it wasn't very well explained I think I've managed to do it. But just wanted to check if anyone knew the issues if it wasn't set up correctly. Car idles just below 1000. And seems to change gear ok. Is there a better guide elsewhere or do you think it will be ok?
IIRC the TPS is adjusted while you measure the voltage or use a conzult
Yes that's how I set it up. With a multimeter but the guide wasn't very clear. Also while I'm here was gonna do a oil and filter change. Due to the hot weather do you think 15/50 would be ok?
Make sure your multimeter is precise. That's how I did it first time and car acted strange, shifted gears in an odd way. So I connected consult cable and discovered that my multimeter was way off, adjusted it by consult after that.
