Managed to damage the trim panel behind the seats. The plastic covering at the scene of the crime is permanently deformed, so I'm after a
replacement. Not bothered by the condition or material of the lower section, but the upper section needs to be as new please.
Hi Andrew, the reason your replacing.......is it the mark in the middle of the panel?
If so have you tried the hairdryer heating to make the plastic return to it original shape???
Russ
The hairdryer will probably separate the vinyl from the plastic. :(
I've got the panel you're looking for here with no marks, but the vinyl's started to lift on it - if you want it, I can reglue it with hitemp adhesive and send it out to you for £30 delivered.
Could you put a picture up for me please?
Edited by AndrewG
