- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Hi Guys, I've been having little niggly problems with idle/stalling/hesitation.... I've seen the threads about a whole load of problems regarding this. Now, as I can make out there are quite a few adjustments that can be made which will effect the idle rpm, for instance, tps, throttle body balance even the cable adjuster, but what I would like to know is this, in what order do you make all these pertinent adjustment to set the idle, I have been going round in circles adjusting, re-adjusting, I cant seem to nail it down.
So can someone tell me in what order I make them and how to zero everything at the start.
Rich
ps just as I thought I knew all the ways to adjust things I read a post by groover giving me another one (Take off the yellow plug of the IACV with engine running and with a flat blade longish driver, turn the idle screw, once the revs are down to about 650 or nearly dying, plug the iacv plug back in and the ecu will take over the idle. )
