Two things!
1. Radio fitted - No power!!!
Where is the fuse box for power to radio or is it from battery?
2. Where is the brake pedal switch for brake lights?
Art
Driver's footwell. 20a fuse iirc. It's toward the back at the the top. Make sure your HU fuse hasn't gone first and that your battery has power!
Cheers, found, all fuses good!
Back inside the Z it appears that the big multiple conector that fits to my ISO has four wires cut! & There small wires!
With masses of wires in there & taped here & there! Im at a loss!
Also spent an hour on my back looking up at my brake pedal switch. Why so bl---y awkward these zds!
It appears there is or should be a green rubber pedal stopper on it. Well mines disintigrated which now my brake lights r on all the time!
So anyone had this problem of trying to fix it?
Now if u upside down in the drivers footwell u will c two switches!
The left switch looking up is to do with cruise control! It is the right hand switch that the green rubber stopper ( brake) disintegrates then the rear lights stay on! This is what needs sorting!
Awaiting DVA registration
Art
