braided brake lines fitting
Hi all
Fitting my brembos and am at the stage where I connect my new braided hoses and detach the old one.
Can someone clarify where I conect too. Seems to me like there is only one place which is where the thin pipe meets the thick pipe on the drivers side its up and to the front of the car inline with the bottom of the suspension spring. Is this correct or am I wrong.?
Thanks . Is there a special way to undo the nut as it wont budge. Used wd40 and all sorts I dont want to bend the hard pipe
Ok used a flare nut spanner and spanner on the flexi pipe union but the nut wont undo its slowly rounding off ive sprayed rust away stuff wd40 but still nothing wont budge. Using 10mm flare nut wrench. Any tips? Other than give up
I have the same issue I heated it up with a small blow torch and that worked nice the pipe you are keeping is all metal so its safe the rubber part that goes to the brake it rubber but if its damaged by the heat it don't matter as its going in the bin any how I just heated it up a little didn't go mad but it work for me.
if you have rounded the nut like I did at first I ended up using a pair of mould grips on one side and the flair nut wreach on the other part
put something heat proof behind the pipe so you don't set fire to the stone chip paint in the wheel arch if you do this
Cheers dan im leaving it to rest for today will crack at it tomoro
that worked for me the wd40 didn't do bugger all just watch you don't set fire to the stone chip or under seal. have the hose or bucket of water near by just incase
Tried that andrew. Did nothing lol. I went and bought another hex flare nut wrench this evening and a blow torch. So ill have a crack at it tomoro. Some pics to see what it will look like.
p><p>
<img src=[/img]
looks great. the blow torch will work just put something to protect the stone chip
