- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Hi,
Have recently developed an intermittent misfire on 'low revs' (around 1500 - 2000 mainly) and this when going 'light' on accelerator. If I floor it (or just have a bit of heavy right foot), then there is no misfire at all. I also get a bit of 'splutter' and the odd 'light back fire' when going off accelerator and decelerate (again this mainly happen when revs pass around 1500 - 2000). Car is a manual NA.
Spent a bit of time looking into this today, and have determined that it is the 'left bank' (even cylinders) that has the misfire (can hear clearly that it is in left exhaust - right sounds perfect). Cleaned out injector, coil pack and ECU temp sensor connectors, but has not made any difference.
Checked injector resistance and injector 6 (left bank - rear) have a reading of 14.7 ohm, which is a little bit higher then the rest (they are 12 - 12.8 ohm). Have replaced injector 3 and 4 before and when they went the reading was 80 - 120 ohm (from memory - I know it was much higher then around 12 ohm that I understand is what we should have).
I suspect (guess) that injector 6 is on way out, but is 14.7 ohm 'high enough' for it to cause misfire ?
