Are all Z32s ABS? or were there none ABS models. Will a S/R none ABS, BMC Fit?
Hey everyone.
Quick question, were all Z32s fitted with ABS as standard? or were some None ABS? Looks like mine has it fitted and I will be removing it.
If there is no None ABS model, then Im guessing I can use a None ABS BMC from a R33/32/S13/14 etc. They look the same.
Worse case senario I'll have to run one outlet port to the fronts and one to the back with a bias adjuster.
I only need to do this as a stepping stone to a cool mod. Please don't call me an evil minion of doom for not wanting ABS :) It's a drift car remember and trust me it's more dangerous to have it lol.
Only few of the very first na's didn't have abs, after that it became standard until around 96-97.
Just pull the fuse, that should stop it working lol
I want to remove the whole system :) I don't like half a job bud and I'm removing everything not needed... I'm a bit picky lol!
As above or stick it on a switch, I believe jimmyTT did that. Function for track, safety for road.
As above :)
Up to 95 base NA is non ABS.
(Which is why mine doesn't have it)
I'm sure mines a 94 NA... so it shouldn't be ABS? I wonder if I just "think" it is lol
I may have to follow the lines..., I assumed it was ABS because I can only see 2 outlets from the BMC... on my skylines etc the ABS cars have 2 outlets and the None ABS cars had 3
Where in the boot is the ABS module? I can't find it. but my BMC certainly has only 2 outlets
If none ABS cars have 4 then they are totally different to R/S bodys
You have ABS then if you've just got the two. The ABS unit is in the boot behind the drivers side arch covering. You'll need to undo some of the mouldings to get at it.
the Non ABS is 3 port to what i can remember BM50 unit and is used on the S models and older .. the ABS is 2 port BM57
It's a 4 port according to the service manual for non-ABS models. I don't know if they were updated later on though..
awesome thanks!!!
Definitely a 4port for nonABS as I used one for many years before going to a pedal box
awesome thanks!!!
Your welcome mate :)
my mem is bad .. its been some time since i had an None ABS breaker in
Mine too Mark..lol I just remembered it from when I had to refurbish my whole system..
my plan is to go pedal box in the end. I have one in my loft a Tilton 2 pedal, but the bias adjuster is seized and i don't have any master cyliners... throw in the cost of brake lines and it'll have to wait :(
