Hi guys,
I need to replace a few things on my car but as you probably know i live in Bahrain and the guys over here always nedd a "sample" before they can get you a duplicate part.
I need to know part numbers and sizes if possible for the following items i think i should change.
Alternator Belt
AC Belt
Power Steering Belt
Timing Belt
Timing Belt tensioner
Exist Bearings x2 ????
Oil Seal x4
Engine Seal x1
Fuel Pump
Fuel Filter
Anything else you guys think i should replace.
I suppose i just really need info on the first 6 items on the list. That list comes from a guy at a garage which i use. But again the guy at the garage needs a sample in order to get the parts for me. Lets say i let him do it all and he cannot find a part for my car, it will be off the road until i get some from the web. Thats why i need your help guys.
Mr.Smith
90 300TT
Well while you are at it you may as well do the water pump, thermostat and plugs. :)
Originally posted by Mr.Smith
Alternator Belt - 11720-F6600 BELT - FAN
AC Belt - 11920-F6501 BELT - COMPRESSOR
Power Steering Belt - 11920-F6501 BELT - COMPRESSOR
Timing Belt - 13028-16V00 BELT - TIMING
Timing Belt tensioner - 13070-45V03 TENSIONER ASSY - BELT
Exist Bearings x2 ???? dunno wtf???
Oil Seal x4 - 13042-16V00 SEAL - OIL x4
Engine Seal x1 - 13042-16V00 SEAL - OIL x1
Fuel Pump - 17042-37P00 PUMP - FUEL x1
Fuel Filter - 16400-N9600 STRAINER ASSY - FUEL FOR GASOLINE x1
VVT springs and seals in the end of the intake camshaft:-
01001-00191 SEAL - OIL VALVE x2
13072-45V20 SPRING - TENSIONER x2
PCV Valves and breather hoses:-
11810-30P00 VALVE ASSY - CONTROL x2
11826-30Pll HOSE - BLOW BY x1
11823-40P00 HOSE - BLOW BY x1
11823-40P10 HOSE - BLOW BY x1
11826-30P01 HOSE - EVAP CONTROL x1
Water pump, thermostat, 2 hoses from heads
21200-42L00 THERMOSTAT ASSY x1
14055-F6511 HOSE - WATER x2
21010-22P25 PUMP ASSY - WATER x1
KP510-00150 GASKET - LIQUID x1
Fuel pressure regulator and dampep:-
22670-30P00 REGULATOR ASSY - PRESSURE x1
22675-30P01 DAMPER ASSY - FUEL x1
And it would be daft not to do an oil change:-
15208-SP099 FILTER ASSY - OIL x1
11026-01M02 WASHER - DRAIN PLUG x1
HTH,
CheerZ,
Andy
Hi,
Why don't you try someone like "Courtesy Nissan" in the USA for the parts.You can buy on-line and they will send them mail order.They do complete kits for the timing belt change.
http://courtesyparts.com/
JEZ
Thanks a lot guys.
Andy, thanks for the part #'s
Jez, I will try Courtesy Nissan, thanks.
Gio, cheers.
let you know how it goes/went
Mr.Smith
90 300 TT
hey jez, or anyone
my car was originally a turbo but the PO had a new engine put in it. Do i order the Turbo timing belt kit or the non turbo?
My engine has not got the Twin Turbo" badge on the head and it has one set of (2) air tubes from the engine to down somewhere ??? :-)
Ben
Sounds like you have the non turbo engine,
so you'll have to order parts for the non turbo.
-Eric
Ok Cheers
Mr.Smith
90 300TT
