Paul C I need some info :D
Hi Paul and others,
The reason I am driecting this email at Paul is because he has what I am trying to do. which it fit my kenwood 6x9"'s into the door.
Apart from cutting the pannel did you need to do anything else ?
hiya bud - the way i done it:
remove door panel (obviously!) & behind is a mounting bracket that the speaker fits in, the outside of the bracket is about the same size as a 6x9 speaker.
I cut the inside of the bracket out with an angle grinder, then rewelded the 2 skins together again to give it strength. mount the speaker.
you will then have to cut the door panel to fit over the speaker, & mount the speaker grille to the door panel.
looking back - it may be easier to do away with the origional mount & make up a MDF mount instead (changing rooms stylee!!:D )
its not too bad to do tho.
Daaaaaaaam,
So it wasn't that easy then !!!.
When you said they fit with a little cosmetics I thought you were just refering to cutting a new hole. I didn't think I would need to get my angle grinder and mig welder out. :( :(.
Looks like I'm going to have to take this in to an ICE shop :(.
Thanks for the info anyway.
well its easier than many things but harder than some! :D
LOL. Very Wise words
Do you think I could put them in without the angle grinder and mig welder ?
I think I'm going to have a crack at it tonight.
AndyZ, do you have any door pannels spare before I start :D
Wish me luck.
