rough accelleration
took my zed out for a blow out ..
as always kicked up like the horse it is..
but now when i step out seems a bit rough
then it goes like hell. last experience with this .
one of the spark plugs ,the little cap on them one was up .
pushed it down and was ok .. i checked all
spark plug connectors and seems ok ..
any advise .. would be welcome...
Is this low speed roughness or throughout?
If it's low speed, clean the throttle bodies. If it's throughout, hopefully there'll be a techy along in a minute!
OK, I have to ask this - where on the island do you give it a blow out? Not much of the tarmac is smooth and almost none of it is straight!
Cheers - Gio
well its rough at low speed . and
as you know montserrat not too mugh straight roads
.. went to this place we call lookout roads smooth
but not too straight.. thanks much..
For the throttle body clean, I found this on AndyP's site http://www.300zx.org.uk
http://www.twinturbo.net/ttnettech/tb/tb.html
I think Jeff also said you have to clean the back side of the throttle butterfly valve as well.
The point of this is to ensure that the airflow is nice and clean and doesn't confuse the ECU.
After Jeff did mine, the low revs roughness disappeared completely and gave a lovely smooth pick up.
Once done, you shouldn't have to do it for another 10 years! And I think opinion is that this one of the first steps to do to cure rough running problems just to eliminate it.
(Given the 20mph limit, what about the police? Or did you have a go during their anniversary function at the Bitter End?)
Well I reckon you should clean the throttle bodies once a year and I reckon the more knackered your turbos are then the more often you will have to do it !
I also found that just resetting the ECU (after cleaning the throttle bodies) made my car run very smoothly.
well i went straight out and bought some gumout
ask my mechanic to clean throttle bodies..
hope it will be zoom zoom .
will post if all is ok.. thanks for adv....
had my trottle housings cleaned ecu reset ..
my zed kicking assssssss..
hope all my troubles be this easy.. knock on wood..
... zed for life...
Nice one, dude - have a Carib for me :)
No have a Stag beer instead, tastes nicer than Carib and its cheaper, Oh bollox I want to live in Tobago!
Group buy on emmigration!
