May 26, 201412 yr How easy is it to remove the steering rack with the engine in? And is there any differences between a tt and NA one
May 26, 201412 yr am just in the middle of refurbing the front sub frame with uprated bushes I have removed all the wish bones front up rights and hub tension rods ect will be removing the front sub in the next few days. I did my rear sub not to long ago
May 26, 201412 yr here the rear I did, doing the front to the same standed http://www.300zx.co.uk/forums/showthread.php?176081-my-rear-sub-refurb-with-pics
May 26, 201412 yr Author Think you meant to put that on my other thread. Lol Looks good tho, are you just using the master kit?
May 26, 201412 yr yes but I got all the back ones when I did the rear. and just ordered the front one last week there isn't many on the front
May 26, 201412 yr Author Check out this item I found on eBay: http://pages.ebay.com/motors/link/?nav=item.view&id=180735011579&alt=web This is what I've just ordered, is there anything else needed? Are you doing anything to engine mounts??
May 26, 201412 yr just looked you need sway bay bush that in the kit control arm bushes that's in the kit it say front strut rod bush ? I like it its the on on the damper I fitted new koni dampers so did need that one, I also am fitting steering rack bushes cant see that in the kit - - - Updated - - - no engine mounts are fine
