front rotor removal
As the title suggests. How do I get it off. Calipers are off ready. Im keeping the rotors so dont want to destroy them while removing. I snapped a wheel stud by overtightening it. The reason for removal.
ย
I changed my front brakes yesterday and, once the calipers completely separated from the hub, the disc should just slip off. If it seems to be seized on, you could either tap it with a hammer or use a suitable sized bolt in the spare hole(s) to force the disc away from the hub.
Yes thanks. I was just being too soft on it.. gave it a few big wacks with a block off wood between hammer and disk. It came off no trouble and ni damage
As above, screw 2 bolts alternately slowly into the two holes near the centre, it will easily prise off.
When you put this back together be very wary of using copper slip to stop thing seizing together. I was recently forced to beat a good friend to death after he put copper grease on my alloy wheel inner and it flicked outward onto my BRAND NEW KSPORTS.
ย
Hashtag, not a happy bunny.
My Chief Engineers phrase for these instances has always been "Don't force it, use a bigger hammer"
Zed #2: 1998 Midnight Purple 2+2 NA. (owned 2020 - now)ย
ย
