Standard airboxes
Evening Chaps.
Can anyone tell me for sure if the standard NA air box is exactly the same as the TT. I think it is because there is no separate listing for air filters, but want to be sure!
I have access to an NA breaker that's all.
Cheers...
If you are after the air filter filament then both are the same size and design.
I figured the elements were the same, but wondered if the actual air box is the same. I currently have a cone filter fitted and want to revert back to stock, I have access to an NA breaker so want to know if they're the same?
Cheers...
:biggrin: TBH just like the idea of binning the filter elements each year and replacing with new ones which with the Apexi and such like is more expensive.
Doubt I'll ever get it concourse, but hopefully in time it'll get close!
I like a standard car bar wheels, exhaust & a mild power increase! Don't mind subtle trim mods and the like either, but really feel Nissan got this car spot on back in 1989!
I'll be looking to refit the standard gear shifter soon too! Its currently got a short shifter.
Im pretty sure the air boxes are the same the only difference is the recirc valves on the TT which are further down the pipework.
I have a standard airbox spare, I'll swap it for your short shifter ! :)
