Stalling
So decided to take a spin after a few months in storage and the car stalls in gear at around 3000rpm :sad: It revs perfectly fine in neutral. Checked connectors, plugs, air leaks and all seem fine. I haven’t got access to a Conzult but will run the manual ECU diagnostic at the weekend. I’m guessing it’s a fuelling issue (pump, fuel control unit, fuel filter?). Is there anything else I should look for?
Possibly fuel pump control unit behind the drivers rear panel next to the rear seat, corrosion on plug or problem with the board, there have been a few issues with this in the past,
I suspected the fuel control unit and guess after 22 years it might have given up! I think there's a temporary bypass procedure to confirm if its the culprit. I'll look at the MAF, per olliezx.
Could faulty o2 sensors display my symptoms? Any other items I should look at while I get my hand dirty this weekend?
