300zx timing question by software
Hi guys,i have a question about the timing,so i got a consult cable and free software along with it.On the software it shows IGN TIMING and in a box across from it 0 BTDC,My question is,can i set the timing going buy the software so it shows 15 degrees BTDC on the software,as i dont have a timing light.Thanks guys:pint:
You really need to use a timing gun to be sure mate. I've seen conzult being 15deg out compared to the gun.
IIRC conzult will give you the ignition timing that the ECU is reading (after it makes any adjustments from sensors etc.) nd not the real timing from the belt
Absolutely, all the Conzult displays is the offset from the actual timimg reference point, which can only be set physically, with a timing light.
