Windscreen
Before I start making enquiries, What would you guys/gals consider a good price for a replacement windscreen (fitted) for '92 2+2 import ?
Depends, the UK colour is blue and easily available can be from £160 to £200 fitted depending on supplier, however some imports ( not all) have a brown/bronze tint which is less easy to get hold of and can be more expensive due to this, last few we have done were blue so cannot say latest price or availability on the brown / bronze tint but expect they may well be around the £250 mark or anywhere up to £500 if you go with the wrong company who says they have to import it from Japan, Pilkington in the UK do make and supply zeds windscreens in blue but not sure about import be worth sending them an email?
http://www.pilkington.com/europe/UK+and+Ireland/English/automotive/book-a-windscreen-fitter/replacement-windscreen-repair.htm
Jeff TT
Thanks Jeff
I've seen other posts suggesting it should be bronzed with a green tint, but I'm convinced it's more of a blue. It's a Nissan screen, whether its original I cant say, it has codes/numbers but no date.
Thanks Jeff
Check your side windows, place a sheet of white paper behind and you will see the colour more clearly, if blue your on to a winner!.
Jeff TT
Well....the top of the screen is definitely blue but the rest of it and the sides couldn't be described as clear tho, certainly some sort of tint to it/them. Good tip re: paper
