Steering wheel issue again!
Thought I'd have a quick peek at the steering wheel issue I have this evening, and it turns out no matter how tight I tighten the two 13mm bolts either side the wheel still shifts from side to side, after further examination I noticed that there is two alloy V shaped sleeves on each bolt which the plate slides into. do these or used to have some form of plastic bush type or rubber? as mine are totally bare. if so where can I get some from please?
Ok this is a common issue, do not over tighten the 12 mm nuts if they snap you will be in a whole world of pain to correct.
The two v shaped brackets originally have three small plactic pegs that keep everything tight however they can break and hence loose wheel, so loosen the 12 mm nuts and the turn the V shaped brackets at opposite angles to each other to act as wedges to stop the side way movement then tighten the nuts and not an exact fix but will be much better.
Jeff TT
Ha there that explains it. There was no plastic pegs! Ill do that jeff thank you. Did you get my pm jeff?
Yes just just sat down and looking through my messages and emails etc will reply soon as..
Jeff
