Hi folks,
I spotted a small blot of oil under the very front of the car this morning - it had run forwards along the under tray before dripping onto the garage floor. It appears to be from the little two-core oil cooler in front of all the other radiators; some of the cooling fins have clearly rusted away and, I suspect, a small hole has formed in one of the cores.
The oil is clean, red/pink in colour - so would the 'cooler be for the auto transmission or for the power steering fluid?
Also, does anybody have a good 'cooler for sale please:wink:
Richard:cool:
Fairly sure thats the PAS cooler Richard, hopefully someone else will confirm.
is yours a uk car like mine the stock autobox cooler is part of the rad. I have a pas cooler on mine as its a uk car but will be removing it soon
Yup - I have a UK spec Dan.... It's the little oil cooler in front of the big oil cooler; if that helps!
its the pas cooler I have one to all rusty am deleting mine soon its like a a few inches long with loads of little fins on it you can just delete it to like I am
Yes Richard that`s the cooler for the pas, another more of that undeniable over engineering by Nissan and fitted to UK zeds not imports, linking out is the quickest and less costly way to sort the issue never heard of anyone having overheat issues with their pas ....
Jeff TT
Yup - sounds like the same thing Dan......
Jeff TT
.......Cheers Jeff; and you're right matey, I have never heard of anyone having PAS overheating issues either! The car is going into the garage for an MOT and oil change on Tuesday - I'll get them to by-pass it with a metal tube or the like:wink:
Richard:cool:
the jap cars don't have it and thay seen fine. I have just removed the diff cooler to as I have the sub frame off at the mo for a refurb
images?q=tbn:ANd9GcRNdQZvFJBOaRkakUvWZnS6x65J1oDOCYrC4JDr7Zv4XgnoX2m_Xw
Jeff TT
:2guns:
best wind your neck in now
