Abs fault
Hello all, the abs light is staying on all the time, it's bein like this since I bought the car, done the diagnostics cheak and iam getting 1 flash, right front actuator solenoid, what exactly is this? Where do I go from here? Quick replys welcome as the car is pulled apart!
Ya Gary just cheaked break fluid all good. @ Andrew I checked the 3 different fuses for abs, there all fine. Done the diagnostic cheak where ya drive the car above 20 mph for 60 seconds+ and iam getting 1 flash in the abs Ecu now.
@Gary cheers bud, that's the tread I was using, il have to keep searching!
Andrew can't get that picture to load, what's procedure 6?
Nice 1 Andrew, that's exactly what I need. Will have a go at this tomorrow and report back..
Checked this with the multimeter and getting 8 ohms between the two terminals so it looks like the control unit needs replacing, thanks for the help lads
