Hi People, is there a disc out there off a different car that is direct fitment on 300zx but bigger?
bigger in diameter ? as with changes in diameter you will more than likely have to space the caliper away from the uprights for larger rotors.
yeah I dont mind doing that, just cant find a bigger disc mate!
have you already upgraded the front? as around 70% of braking force will be from the front brakes....
im upgrading mine with the evo 5-9 calipers and the evo X disks which are 350mm as mentioned in my build...
my rears have stock disks with stock pads.
If you really want to go down this route, why not move your front calipers to the rear with the stock disks, and get a fabricator to make you some relocation brackets. its what i was going to do but i didnt want to run a bias valve because of the risk of easily locking up the rear end.
