After get the zed I have not had the time to even think about her. So after being sat for a while I started her tonight. Flat battery but started as soon as she was hooked up. Let her sit and run but got up to temperature quicker than she should (10/15mins at idle) Kept an eye on it then the fan sounded like it was working overtime.
ย
Let her keep ticking for another 15/20 mins and maintained temperature at just under halfway but leaked coolant somewhere from the back of the engine (can't see to much due to the dark).
Since I got her the heaters never blew out hot air but did the easy check the footwell but bone dry so likely this leak is the cause of that?
ย
Any ideas or help much appreciated
Check that the matrix has not been bypassed by looking at the back of the engine, ensuring that the 2 heater pipes are connected to the 2 copper pipes coming from the cockpit through the bulk head.
ย
They are the two sat above and below each other more to the left hand side of the engine? If so they are both connected and not a drip below them
Could be coming from the Turbo mate or under the plenum chamber. Do you know if the water pipes under the plenum have been bypassed?
ย
I have no idea and wouldn't know where to look under the plenum chamber
