Air Flow Meter
Has anybody got an air flow meter for a 91 auto na import, as I understand this could be causing my problem with the revs dying off at 2000 or so.
Or has anybody got any other clues.
ECU diog is clear?
  • Replies 27
  • Views 2k
Do we know whether the TT and NA ones are different ? May need to check the parts CD biut I don't have it with me right now.
You would be well advised to try a known working one from someone else, 5 minute job if you have an aftermarket airfilter on each car, 5 hour if you dont ! ;) lol
I have a spare TT one but Macca still has it at the moment :mad: (;) )
No Probs littleP,If he wants it I can post it direct to him;)
I would be very much obliged gentlemen.
E mail me direct and I will let you know where to send.
You need to get someone to confirm that the TT and NA parts are the same though ....
According to the TTnet parts fiche they are the same part (22680-30P00) for the TT and NA MT/AT.
Thanks again gentlemen.
please can you send asap MAC1, if its ok by AndyP of course.
E mail address: ray.badgery@ btinternet.com or as profile
Ray,mail me your address,I will post it tomorrow If that's ok with littleP:D
MAC 1
did you get my E with the addess
thanks for your help
JeffTT thinks its the AFM also.
I hope its that simple.
Originally posted by raydetinu
MAC 1
No mate nothing yet.
MAC 1
sent another E, must be them gremlins again
can you please send to
QAS Ltd.
Unit 3-4 Abbeywood Park,
Emma- Chris way
Filton,
Bristol BS34 7JU
Attn. John Lovegrove
Thats where sick car is awaiting therapy.
Thanks again.
Will send today,along with TT Tims bits;)
Your car should be running tomorrow;) It's only a 10 min job to fit,I sent it today First class;)
10 mins with a standard air filter box - I don't think so ! :D
Ok 12 then:D
I'd say 10!
Originally posted by Timmy_Turbo
I'd say 10!
LOL Tim you and your bro took half a day:D
ROFLMFAO :D
GLOVES ARE OFF! :D
My service garage has got part, thanks MAC 1 and AndyP
I will let you know how long it took them when I get the Bill!!!
My Guess is about 2hrs.
Do we want a bet on this you two?
Loser pays the bill....
Hehehehe - you're the loser - you're car is broken ! :D
So what happened, is the car now running?
Not a sausage ......
Tumbleweed time !
OK, sorry about delay in letting you Know how things were going.
The car is now running OK, and put new boots on too. ( Falken 451).
I digress,
After changing AFM and it not making any difference, they went back to the wiring and chased back the spurious voltage readings from the ECU,s and guess what, water had got in to the main connector block under the dashboard.
Water from the drain pipe to the roof, which runs down the A pillar, and supposed to discharge to the outside didn't and was letting water drip onto the wires and run into the connector!
So, I can now return the AFM to Andy, let me know where to send and I will post asap.
Once again thanks for your help.
Moral - check the simple if not obvious things first!
:rolleyes:
