what offset is best when fitting 18inch 10j wheels on the rear
whats the best off set for a 10j rear wheel ? and whats the max tyre you can run on a 10j rim
and whats the best off set for front for a 18 8.5j
Edited by dan300zx
will I get a 35et 10j wheel in the rear maybe with the arch rolled
I think et20 is going to need to work to the wheel arch to get it to fit am sure et20 will be sticking out a fair bit am sure one one will post with the info soon
Yes, they will go on lovely with a little lip roll depending on the tyres you go for.
I'm going for an 11j et 20 rear, god knows if it will work or not lol
You'll need a fairly substantial arch pull/flare to fit them in unfortunately, unless you're one of these people that like obscene camber angles!
what tyre do you think would be best want the biggest tyre possible was looking at roling the arch thay do a flare now witch it more than just a role would I get a 295 on a 10j wheel
