740cc injectors
Best place is CPZ or Z1 .. if you buy early type then your rail will be fine .. expect to pay around 400ish for New Budget type .. up to 1k for Branded
Edited by MarkDerby
Best place is CPZ or Z1 .. if you by early type then your rail will be fine .. expect to pay around 400ish for New Budget type .. up to 1k for Branded
if you see any nocking about mate give me a shout will u.
top feed or side feed what ever that means, cas i found these.
All have been re-manufactured from original equipment Nissan/Japanese Electronics Corp (JECS) fuel injectors to the higher flow rating and placed in flow-matched sets.
All new o-rings/seals are supplied for installation
High Impedance Fuel Injectors
Specifications:
Condition: Reman
Comes with Flow Sheet
Flow Rate in CC per minute: 740CC/min @ 43.5 PSI or 3 BAR
Resistance: 11.1 ohms
Voltage: 8-15 Volts, nominal 13.5 Volts
Amperage: 1.0 Amps
Pressure: Min 30PSIG/ Max 100PSIG
O-rings Included: YES
Warranty: 1 Year Warranty!
This set of 740cc "Grey" Top fuel injectors is not the manufacturer's original equipment (OEM) spec injectors for this vehicle only. Use for modified engines only.
This set is sold with a set of Denso electrical pigtails.
Specifications:
Condition: Reman
Amperage: 1.0 Amps
Ok Jecs Brand are ok and do make 90% of the injectors on the market Inc Nismo ones
Denso plugs are the type u have now .. standardization type for many more
if there the ones on CPZ site .. Nothing wrong with them at all
cpz site?
there only $450 there abouts so betime u get them here with dutys/vat/post conversion 400quid ... dont think its silly on the cost
tbh your gonna end up paying 250>350 for 2nd hand ones
oh i didnt see thos on there? must have being looking at wrong ones
