2 things
Hi, good evening all
Only just noctied this but maybe ive moved something to make this happen i do not know, on my auto box i have a switch which has Hold and Power , i dont bother with it, but what i have noticed is that when i put my foot down the power light lights up on the right of my dash, is this normal? or not?
Secondly, im not sure if anyone here can help me with this, but i may as well ask, ive probably had my zed for over a year now, and although it did come with a shed load of service history and paperwork, i called zedworld seeing as that most of the work had been done there, i wanted to know if they could confirm what work had been done on my car, in fact i called twice both times they said they would call me back. but i never got a call back, maybe they were busy i dont know. But ive this feeling that they didnt want to call back , or maybe the cars history is all false? who knows... ... does anyone here work at zedworld??
Edited by leeroy73
Secondly, im not sure if anyone here can help me with this, but i may as well ask, ive probably had my zed for over a year now, and although it did come with a shed load of service history and paperwork, i called zedworld seeing as that most of the work had been done there, i wanted to know if they could confirm what work had been done on my car, in fact i called twice both times they said they would call me back. but i never got a call back, maybe they were busy i dont know. But ive this feeling that they didnt want to call back , or maybe the cars history if all false? who knows... ... does anyone here work a zedworld??
Jeff will be along in a mo'.....................
Yes I do, sorry Leeroy you had this issue, the boss can be a bit flakey sometimes always off in Portugal or something!!
Pm me the number plate and will take a look now for you.
Zedworld worker.
BTW-the power light is normal if you stick your foot down..........................
Ok Leeroy can confirm the work below from the worksheets and our client data base for the zed registration you gave me.
G96 ***
14/06/08 Mileage: 68,807
Replace autobox and fit cooler.
Fan belt
Line up o/s door
Oil and filter change
Replace fuel filter
ConZult set up
6/11/10 Mileage: 85,447
Replace crank seal
Replace steering coupling
Oil & filter change
Replace spark plugs
Replace fuel filter
Replace power steering pump ( noisy )
Fit chrome ps reservoir
Replace radiator expansion bottle ( cracked)
Strip out front pads, clean and free off calipers.
Boost leak check
Quote for full repaint and new bumper
14/05/11 Mileage: 85,926
Replace heater matrix pipe ( leaking )
High pressure power steering pipe.
Hope that helps.
Jeff TT
Edited by JeffTT
Thanks for the input and thanks for your time :)
Sent from my GT-I9300 using Tapatalk
