Braking
Hi People, can anyone confirm what percentage of force goes to the front and rear of a zed when you press the brake pedal?
Assuming you are running stock calipers, discs and pads then below the split point of the proportioning valve (498psi) the
brake bias ratio F/R is 2.1/1 and above the split point the ratio F/R is 3.0/1 The proportioning valve is built into the master
cylinder and reduces the hydraulic pressure exerted on the rear caliper pistons relative to the fronts when you apply
pressure to the system above the split point. If you like, between light/medium braking and heavy braking.
Edited by AndrewG
"stock calipers, discs and pads"
Assuming you are running stock calipers and pads then below the split point of the proportioning valve (498psi) the
pressure to the system above the split point. If you like, between light/medium breaking and heavy breaking.
You just beat me to it, I was going to put exactly the same :whistling:.
