Strut Tower Brace
Hi guys,
Wot sort of difference do the Strut Tower Braces make to the handling of the car. Which strut is more important (Front or Rear) for the better handling of the car for normal driving or do they both play an equal role.
Cheerz
"AMMAR"
Ammar,I would say the front if you are only fitting one;)
By fitting both,will be even better.
Within the next 10 days I will be selling some Front ones with brake brace fitted all in one,should work out less money that it would cost you for the standard strut brace;).
Hi Mac,
Can you put my name on the list. I am very interested.
Stuart
and mine:cool:
how much difference do they really make?? look a bit cosmetic only imo, proper race ones usually have a threaded bar to wind the tension on when bolted down. I always thought the fixed ones were a bit of all show & no go
you often find that those with the threaded bar are either universal or multi-fitment though - this was certainly the case on my last car, you had to wind it to length and then fit it, and then tighten the threaded bar to brace the strut towers.
Hi Mac,
cud you please add my name onto your list as well and wot do you mean when you say they have brake Brace fitted???
cheerz:)
