doing my cambelt next week but
are na and TT belts, tentions and water pump different?
got different numbers on the system but most kits say they do both???
thanks.
The same belt and the same water pump, be careful when looking at spurious application guides the non turbo applications may be for the Z31.
Goes with out saying please fit a "Genuine Nissan belt" lots less grief of know quality and correct fit.
http://www.300zx.co.uk/forums/showthread.php?130325-Nissan-V-Blueprint-Cambelt-showdown&highlight=cambelt+comparison
Jeff TT
Thanks Jeff, I'm fitting Nissan parts but the part number for the Na. Bits was no longer avaliable wanted to check . Could order the tt bit
Nissan part numbers that will fit TT or Non Turbo
Cam belt 13028-45P86
Water Pump B1010-22P27
Give mike a call at MJP ( trader section ) he will sort you out quickly.
Hope that helps
Jeff TT
