brake bleeding question
Is there a specail way to bleed these cars and especally now when ive just spent the last two days in replacing 80 percent of the brake pipes. is there a bleed niple under the hood as well on the wing or is that a clutch one? cheers
thants the clutch one mate on the wing near the hicas, there are 2 nipples on the abs unit in the boot that need doing as well.
agh forgot about the two in the boot, is there a guide or is it ? always start on the furthest caliper away from the brake master cylinder fisrt then work you way in the your abs two nips ie. nsr then osr then nsf then osf then abs nips in boot?
Pre '94 models have two bleed nipples on the ABS unit. Make sure you follow bleed order and
procedure as per FSM:
http://www.300zx.co.uk/tech/manual/manual/br/005.gif
You will need to bleed both sides of each caliper, outer nipple first then inner nipple. ABS nipples
are marked F and R.
without having the caliper in front of me and my pooh memory has the caliper nipples locted one on the inside and one on the outer or is there a left and right nipple on them. cheers
