decat fitting info
The pipes obviously dont bend out far enough to miss the autobox which is larger than a manual, however i bought some jaspeed decats years ago on an N/A auto and they fitted on mine, bought i sold them on to another member with an auto and they didnt fit.
You could get the pipes bent out a bit to fit at an exhaust place if they have the facility.
does no one do a set for the auto then that you don't have to start messing with to get them to fit ? are thay all for the manual then
im looking to get the megan racing downpipes and test pipes from concept zed, i messaged them and they said they do fit the autos :D
The Japspeed pipes will fit an auto with a little adjustment or two, the passenger side one is ok its the drivers side runs close to the corner of gearbox sump, a little light dressing of the pipe with a hammer will sort it, have done many and always got them to fit.
Jeff TT
