protoj · Tuesday at 18:48 1 day
Hi guys,I just got a new battery for my z,the car way lying for a few years and I was just testing out the electrics but for some reason the front indicators won't work,would you guys have any idea why this happened as they were working the last time I drove it,any help would fantastic.cheers lads :no:
