September 4, 201312 yr After respray i have no single swirl mark on my car :) whats the besy way to clean it wirhout scraching it ? :)
September 4, 201312 yr Depends how you want to do it really, could go the snow foam route or there is always the 2 bucket method with a lamb mitt! Main thing is a good rinse to remove and loose dirt before starting!!
September 4, 201312 yr Light pressure (spray pattern) water of light dirt Two buckets one for wash with shampoo one for rinse after each sponge on the car. Rinse water off with light spray or fresh water and good quality wash mitt...dont use it like a glove (creates pressure on the surface and could trap rogue contaminants) Dry with synthetic cloth and wipe over with microfibre. Use a Clay bar treatment to lift any road dirt form the paint Apply a good paint cleaner dry off with Microfibre Apply good quality polish and use hand or electric polisher, poish off with microfibre If swirls apparent, apply anti swirl polish as above Then a coat of Wax if required. Car should be swirl free and causing you eye pain with shiney finish, LOL! Important thing is not to mix clean and dirty dirty water so ideally use two buckets and never presuure wash the car when dirty or those nice little grains of dirt and grime will happily etch themselves into your paintwork! Every one has there own way of doing things..and when I want to do it properly this is mine. For an inbetween polish you can get good all in one shampoo that should make the job quick and simple.
