Me again.
So I have two questions:
RobHowl ·
hello I wonder if the configurations of the APEXi SAFC II station right
SETING
TH POINT LOW 30 HI 50
DEC AIR
THR 48 %
NE1 1.2%
NE2 2.7%
KNOK SET
0 RPM
1: 0 1500RPM
2: 0 3500RPM
DATA FILE
FILE 1 :ON
FILE 2 :OFF
ETC
SENSOR TYPE : HOT-WIPE
CAR SELECT 6
DISPL SCL
PR 2.0Kg/Cm2
NE 8000RPM
CR +/- 30%
WARNING SET
KARW 1600Hz
KNKW 40
REVW 8000RPM
if you have something wrong please help me
forged piston and connecting rod
thanks :tongue_smilie:
