Climate Control problem - mode motor ?
Hi,
My AC is working and blows cool air, but sometimes (especially if car has been used and then only parked for 15 minutes) it is like the air is not getting into the car. It can also happen when driving, and then it happens after about 20 - 30 minutes. The amount / volume of air that will pass through the vents in the dash will reduce to about 20% of normal. I can hear the fan still running, and some air is getting through. Also if I change (it is a 1993 Series 2 car with Auto Climate which I can manually change direction of air on) the direction of air, it seem like it is making a difference, and air distribution is changing (a bit hard to say, since volume of air is low).
If the car is parked over night and I start in the morning, it all works fine with lots of air getting into car.
It is a bit like no air is getting into the 'blower unit', and I suspect that this electrical and one of the motors (or sensors) that control the climate system that intermittently is acting up (which makes it harder to figure out what is wrong).
Looked a bit and believe that the 'mode door motor' is prone to fail. Have anyone experienced this and have it appeared similar / same.
Any help / advise that can be shared would be appreciated.
No posts to show
