Headlight earths
Hi guys just getting the Z ready for MOT, and one of the dip lights are dim, but the bulb looks fine, so thinking its the earth somewhere, does anyone know where the earth is as I cant seem to see it.
cheers Tom
I'm not certain but I'd imagine its the bolt going into the chassis rail just behind each headlight. Make sure the bulb is good though first
Unless anyone has done an earthing mod for hid lights, then the earth wire from both dipped lights and from both full beam go to a change over relay in the big engine bay fuse box.
[sIGPIC][/sIGPIC]
JDM and UK are different... what is yours?
go for the HID conversion and use a new relay to supply power to both...
the standard dipped beam on the Zed's are 5hit!!!!
Tom if you pop into shrewsbury take a drive upto monkmoor industrial estate.Ill show you where the problem could be..Lee:wink:
