how to remove ecentric bolt from rear camber arm ?
ok am fitting rear ajustable camber arms the bolt that bolts the arm the chassis i have removed the nut the bolt spins free but wont slide out whats going on here have spun the bolt round a few time but just wont slide what am i missing here
Have you undone the end attached to the hub?
May become easier to remove the eccentric bolt with the arm in the free position.
If memory serves me right, the flange of the bolt comes very close to the flared edge of the fixing point.
yes all nut and bolts are out bar the eccentric one that bolts the chassis if i dont get a better idea come tomoz am going the grind the bolt out there must be a better way am sure but what ?
yes with a lump hammer its free like it spins round fine its like somthing is locking it in
Is the adjusting washer still in place? if you have turned the bolt end and not the nut end the washer gets stuck on the shaft of the bolt as the detent has been forced past the engagement point, if so this needs realigning to get the bolt out
The picture is not exact but gives the idea, if the washer has gone past the flat it will be locked onto the bolt, you need to hold the washer with mole grips or similar and turn the bolt until the washer lines up and is released and then the bolt will come out.
Jeff TT
Jeff TT
[ATTACH=CONFIG]72220[/ATTACH]
i see ok thanks will have go at that then 2moz
